Aout +/-15 volts
Is there any problem running the aout module on +/- 15 volts?  I was  thinking of building it as a module in my synth cabinet and running it off the synth power supply.
Thanks
should be no problem :slight_smile: but are you planning to put a MBSEQ into your cabinet as well or did you just post in the wrong board? :wink: :stuck_out_tongue:
seq. will be outside of the synth cabinet.  But this way I only have to run 5 or maybe 13 wires from the sequencer to the synth.  A monitor cable will work nicely.  I can have the data, power, and triggers go through it.
Where should I start topics about the aout?
As long as it’s a general hardware question that is not related to one certain application, post it to the Design Concepts board - or, if you´ve already connected it and it smells strange: Testing/Troubleshooting :wink:
S
