Hey midiboxers,
I’ve spent a lot of time over the past few months figuring out an efficient method for doing panel silkscreening, and ended up buying a lot of supplies in the process (more ink and emulsion than I will ever need.) A few people have expressed interest in getting panels silkscreened, and I’m about to be doing a few more of my own, so – anyone want in?
I’m going to limit this batch to about a dozen requests. Just prefacing with that, in case demand is higher than I expect.
Keep in mind, I’m no print shop owner, but I’ve been getting great results (see attached image – more images coming soon or on request.) I’m using professional Plastikote ink (the kind reccomended for printing on metal and plastic) and 220 mesh screens, which give a really detailed print. I also have many ink colors available and can do multi-color prints.
I’m not sure what a fair pricing schema would be, but it’s just going to help me pay back some of these supplies, so I’ll make it cheap. 90% of the work is in the setup costs, so multiples of the same panel will be cheap. If these prices seem too steep, I’ll swap or discount for components, PCBs, hardware, whatever, if it’s cool. ![]()
Here’s the deal:
Screenprinted Panel
$10 setup fee + $0.25/square inch
$5 for each additional color
$0.25/square inch for each additional identical panel
Shipping costs TBD.
– You ship your panel to me. $2 discount if you send me a transparency of your artwork – otherwise I need a 300dpi flat b/w image for each separate color.
– Color choices: White, Black, Red, Yellow, Blue, Green. I can lighten or darken colors as needed. If you need a color I don’t have, or fluorescents/metallics, I’ll get it, but need +$10.
– Payment via PayPal or money order sent w/panel.
Example:
Two 1U MOTM format panels silkscreened with 2-color design:
$22.66+shipping
Things I will also happily do to keep my hands busy and my projects self-supporting:
– Design your panel artwork.
– Etch PCBs.
– Buy, drill (circular holes only), polish, and paint (auto primer+auto paint+clear coat) your panel. I order custom-cut 2mm aluminum panels from onlinemetals.com. This saves you shipping. Won’t be accurate to the fraction of a millimeter (i just use a hand drill, clamps, and a uni-bit), but it works great for me if it does for you.
– Paint/coat colored knobs w/modeling paints.
Contact me for costs on any of that other stuff. Just reply here or e-mail lars[at]8cac.net if you want to make an order.
In the spirit of synth DIY, I’m writing a guide to DIY panels to share the experience I’ve had… first post is on my blog at www.larsattacks.com. Glad to answer any questions.
If this post needs to be moved to a different board, please do so…
