Anyone had success with this encoder?
anyone??
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=MRE-1&type=store
will it work?? why does it have so many output pins??
bye, from Steve
Presumably it would work. I have no clue as to why there are six outputs but that’s probably nothing to worry about - some pushbuttons have eight outputs of which six do nothing for some unfathomable reason. They are pretty cheap so at most you will throw some 8-16 dollars away which isn’t too bad (I assume you won’t be mass-producing LC clones).
Anyways, remember these encoders are detented. That means you cannot use TK’s interpolation routine and in effect you get 32 pulses/rev instead of 72. That could be too coarse for your purposes if you wish to have a working range of one revolution.
I’m not sure if this rotary encoder is really applicable for MIOS. The additional pins are not documented, maybe they are used for a push-button function (this would be great) or they are used in conjunction with another movement coding (thumb down)
This is the webpage of the manufacturer http://www.nobleusa.com/
Unfortunately the datasheet of the SDE161PUB encoder is not freely available…
Hey…
I got in touch with them and received the datasheets a few hrs later… i’ve put them here:
http://www.notapplicable.co.uk/mbhp/sdb161_1.pdf
http://www.notapplicable.co.uk/mbhp/sdb161_2.pdf
http://www.notapplicable.co.uk/mbhp/sdb161_3.pdf
From what I can make out the extra pins are indeed for the inbuilt switch ;). It is the 5bit version with 32 5bit electrical positions and 32 5bit mechanical detents…
Are these good, they’re a bargin if so…
Peace
Dan
So what do you think TK ?
Ian
Thanks for those replies, it is appreciated.
those data sheets are a bit mysterious to me! (I’m still have a great deal to learn before I feel confident with digital technology!)
from Steve
Don’t buy these encoders, 5-bit coding is good for developers who want to drive discrete logic with the encoders, but useless for microcontrollers, therefore it is not supported by MIOS. MIOS only supports the common 2-bit coding.
Ok thanks for that Tk…shame but.
Ian
Hey, thanks again for the replies!!
well what about this encoder…
well I tried to place a link but it dosen’t work… so you will have to do a search for 3315 encoder at www.farnell.com (p/no. 653 019)
cheapest I’ve found in Australia, also available internationally through Farnell ?.. easy to get?
though I don’t think 16 pulses per revolution is enough?
AUS$ 4.29 for quantities 25 and over
NZ$ 5.28 for you Ian, LO! (I think)
well it’s still kinda expensive I guess! maybe I’ll wait for something a little more cost effective!
bye, from Steve
