Another way to param note
Hello,
In order to param a note, you need to switch to param page select the param then switch back to step edit if you don’t want to be stuck with the dial for step display.
But the seq4 v+ has trigger knob on each step!
Why bot using the trigger in the step page above the note to select the note param, furthermore holding it and turning it will allow seek param select.
Thanks in advance,
Have a good day,
Rgds,
For my own memory: currently SEQ_UI_Button_Enc() just selects “fast value change” mode, we talk about extra (and optional) functionality
So, the request is to select the parameter layer while encoder button is pressed instead of activating FAST function, is this correct?
Only in Edit page, in all other pages still FAST function, correct?
Not sure if this confuses more than it could help… personally I find it useful to active FAST function this way at any page
Yes, instead of doing:
  • Param button
  • Select layer by bottom button
  • Use encoder for setting it.
Or by holding param button etc, which i don’t use because useless.
Just click under note encoder, and it switch to next layer, or hold enc and search the layer you want!
This way you don’t have anymore to switch from step view to param and return to step because in param view bottom row is used to select param not step part (1-16, etc)
Of course the fast button, is to be activated manually if you want after to fast set the values.
Regarding this fast button, i do know now why it light sometimes and i need to switch it off, that’s because it did push the enc to see what it does, well i think it’s not good, a fast button, or a fast by pushing the encoder, but two different way = 2 workflow!
Please not that this is a second workflow idea which the goal is improving further the pattern easier edit access, which compete with the around dial actual described improvement one where the goal is the reduce totally it’s use by putting (step/param/track/mute) on a single page but accessed differently!
