-The idea is to use a step up transformer so the only “thick cabled” connection would be 20-30 cms
Umm.. not sure I get you here.
Steeping up the voltage will allow you to get away with thin cable, only if you plan on stepping it back down to be used.
at what voltage is your load operating at, compared to what voltage you would be stepping up to?
In other words: If you are planning to use the inverter to drive the lamp voltage up to 220, then you still have the associated thick cables required to operate whatever lamps you are intending to use, SAFELY.
Are you planning on stepping up to 220, going somewhere with it, then stepping down to 12 to drive the lamps?
Then you will have an ARSE load of transformers all over the place. Saving on thick cable and replacing it with heavy transformers, for 5 feet of gain.. doesn’t sound very cost effective.
Neither is going to save you on over-all current drain either.
If you are short on money, then its a sure bet that an inverter capable of handling that much wattage is going to be a strain on the budget anyway. Add to it step down transformers (where needed), and you have a very convoluted system.
So, Practically, I think your best solution might be:
Large battery (car, or marine) –> thick cable –> distribution box (triacs) –> thinner cable –> 1 12volt lamp (or string of small series/parallel lamps).
Figure that a 50 watt load at 12 volts still needs about the same size lamp cord as a 50 watt load at 120 volts AC. An automotive headlight would be slightly thicker.
If you stick with Automotive lamps (Headlights, tail lights, interior lights, etc) you cant go wrong. The cabling requirements are pretty obvious, and if not, you can always ask the shop clerk.
If you are using much more than the 4 head lamps, I would use two car batteries in parallel.
In case this isn’t already obvious: A large lamp, regardless of its voltage/current format, will require a large cable. There is no way around this. A load is a load is a load. _ Trying to shortcut this is asking for fire _ .
2500 watts of lighting is going to take some current, and is going to create some heat. No way around it.
Perhaps you should reconsider your plan.
If LED lighting is too expensive (think of the safety of the poor girl), then perhaps it shouldn’t be done.
