I’ve built a controller for a VST Hammond Organ composed by a core (ID 00) with 2 AIN modules with 45 pots/faders,
plus 6 analog buttons, and 1 DIN with 31 buttons, linked from J11 to a second Core (ID 01) with 4 DIN for 122 notes
and 6 buttons.
The PICS have loaded the midibox64.syx and midio128.syx. I’m using only 1 Power Supply(9V - 500mA), no LCD connected.
The issue is that when I power-on, all the analog inputs goes to 0V and the digital buttons don’t move to the positions
set in the hardware. The pots send the correct position to the VST only if I switch-off and then switch-on the Vd from
the core to the ains modules.
Regards.
