Hi everybody, i can’t find the AN2131SC in my country, but AN2136SC seems to be reachable. I watched these chips in a datasheet and the pins 26 and 27 are differents in both, rest are identical.
My question is: There are some posibility to, in example, change some parameter in the source code to make the AN2136SC compatible with the MBHP_USB module? Thank you for your time.
I’ve no experiences with using other chips than AN2131SC (note that AN2131S is a different chip!)
Dangers are too high, that the firmware won’t run without debugging.
Therefore I strongly recomment to search for a commercial MIDI interface instead - in europe such interfaces are available for 20 EUR, so that it doesn’t really make sense anymore to build an own one
