Is it a 50Hz hum type thing, or is it more of a buzz / roar type noise?
The SID’s are noisey F#@ers. I realise you are using the feedback pots, but disconnect these, and tie all the SID input pins to ground (with the small jumpers)
Does the noise go away then?
Regards
Mike
Hi Mike,
The hum was there when the in was tied to ground (the pots took a while to arrive from OS).
It’s a lot worse with the feedback dialed up (lots of noises), but more like the 50hz hum on the lines.
Though I haven’t looked at it with a scope to nail down where the buzz is located.
I could live with it if I have to, but I really don’t want to. The machine is near perfect!
:frantics:
How much gain do you have to give the synth to get it up to a decent level?
Is the hum on all the outputs? I recall some issue once with the switch jack sockets being incorrect.. But I doubt this is your issue, unless you have to gain the crap out of it to get a decent level.
My 6582 is pretty damn quiet, so something is obviously wrong with yours.
Maybe check all your components around the power section.. maybe an electrolytic cap with wrong orientation etc.. It could be that your analog power is too low before the regulator, causing it to sag. What measurements do you get before and after that section.
It’s not likely the 5v supply. (Could be, but I feel unlikely)
I set the input trimmers to 0 and the faders to unity.
The hum is there loud and clear.
You can’t really hear it when playing the lead, poly and bass engines, but is evident with the drum engine in the gaps between notes.
The voltage I get on the psu is 9vac, after the rectifier is just shy of 12vdc on average.
The 5v section drops to 4.7-4.9vdc and the 9v regulator outputs about 8.7vdc
Would it be a problem to feed 12vdc to the 9v regulator without removing the rectifier?
I’m at work for the next 8 hours so I can’t check my cap orientation for a while, but I am pretty sure that they’re oriented properly. While I have built loads of stuff over the years, nothing has been so arduous as building this machine.
That said, if I could spare the cash, I’d happily build another
(expensive, yep, and now cheaper alternatives are available online)
The 5v Rail sucks a fair bit of juice on the MB6582.. about 1Amp iirc. While the 9v / 12v a fair bit less..
You could try to feed in another supply to the rectifier & regulator (option C).. I’m a bit concerned about you measuring 8.7v instead of something more close to 9v. It could be your multimeter, but I thought a 7809 would be closer to 9v.
I did measure 9v from a 7809 on my breadboard fed by a 12vdc supply(no load).
Same with the 7805 I tried(got 5.1v) but that sucker got really hot under load.
While it did power the 5v rails of the mb-6582 it got really got and started to make that electronic death smell so I shut it down.
In any case the Hum was still there, so I think the problem is indeed with the 9vac supply of the c64 psu.
I actually have two of them(c64 supplies), one can only power the synth if I have 6 sids maximum on board. Any more than that and the supply from the 5v rail drops to 1v.
I did as you suggested and mix n matched the different rails via my breadboard and the hum remains.
As it happens I do have a similar switchmode in the house that I bought to use with my MusicFromOuterSpace modular(awaiting rebuild again). It’s a ±15 and +5 supply made by Meanwell(I think 60w, it’s in an enclosure). 15v should be ok on the 9v regulator shouldn’t it?
I noticed the 7809 on the MB6582 barely gets warm, but am concerned about how hot the 7805 got on my breadboard without a heatsink.
Will need to get another heatsink and do further testing to make myself comfortable.
Another thing I thought of after I read your post is that there is concern of the voltage being below the 9v mark after the regulator.
This happened with two regulators, is there a possibility of a bad cap or a solder bridge causing this problem?
Why are you using a 5v Regulator? The C64 outputs 5V.. if it’s crapping out with too many SID’s installed, the C64 power supply is not so good. (It happens, they are old)
How about running your MB6582 Option A (C64 Power supply) with only a two SIDs in.. do you get hum?
(I asked earler, is the noise / hum on all outputs, you never replied regarding that)
I can’t see how your 9v AC can be bad.. it’s just AC from the C64 transformer.. then it gets rectified (turnt to choppy DC).. then smoothed by the caps.. (Bumpy DC) then rectified by the 9v regulator = Smooth 9v DC. (regulator c o u l d be faulty.. only a $2 part, maybe worth trying)
If you used a 5v regulator to get 5v DC.. and you are say feeding it 9vDC, and a fully stuffed MB6582 pulls about 1amp on it’s 5v Rails. The voltage drop across the regulator is gonna be say approx 4v x 1Amp = 4 Watts of heat. that little guy ain’t gonna cope being a small heater for too long.. lol.
If you use a switchmode PS as you mentioned, and feed that 9vAC input on your 6582 with 15v DC, that’ll be fine.. the regulator may get warm / hot but should be ok to try.
Regards
Mike
Oops sorry. I thought I’d got to that point.
Yep, noise is on all outs.
I only started messing with a 5v regulator after both of my c64 psu’s yielded unsatisfactory results.
I have used two different 9v regulators and the noise is still there.
The noise does get worse when i connect the fan, that’s the #1 reason I suspect the regulator isn’t getting enough input.
Yesterday I read that regulators need 30% more input than they output to regulate smoothly.
Will try the 15v PSU as well as remove some SIDS on the c64 PSU that at least powers the whole lot, even if it is noisy.
Regulating 10.5V to 9V with a 7809 is too tight. The regulator needs some Volts to burn.
Also the fact that the voltage drops with all 8 SIDs (= more current consumption) usually indicates that the PSU can’t deliver enough current, which (following Ohm’s law) causes a voltage drop.
Now you get no noise from the switching supply? Switchers tend to be really noisy, if you found one that’s quiet - woohoo! Can we have a sound sample with the new PSU, please?
Hey, no hurry This here is fun, not work! I just really like the idea of having a noiseless switchmode option - a lot of people have been looking for that!
When I built my MB6582, I A/B’d between a switchmode power supply and a C64 power supply.. And even with the gain right up, the change in background noise was negligible.
Many people who are racking up Neve / Calrec / SSL / Ward-Beck etc channel strips are using switchmode power supplies, so I guess they can’t be that bad.
