I am currently looking at some pushbuttons for my midibox project - I found some really neat ones with LED’s.
So I thought of connecting the switch in the button to the DIN and connecting the DOUT to the LED inside the button.
But I am bit lost about the specs of the DIN/DOUT module. I know it’s running 5V but how many amps is it driven of? I am building on the GM5 - is it just the amount of current that comes out of the USB port then?
The specs for the pushbuttons is:
HIGH QUALITY LATCHING DPDT OFF/ON WITH RED LED (CAN BE WORK 3V- 6V)PUSH BUTTON SWITCHES.
FEATURES:
DPDT- OFF/ON LATCHING TYPE, PUSH IT ON, PUSH ITAGAIN OFF
CUT SIZE: 17mm X 17mm (PRESSFIT TYPE)
125V 6A, 250V 3A; CAN ALSO WORK FOR 12V, 24V.
It says that it can work with a wide variety of voltage but I dunno if the amount of current (ampere) the midibox is sending out will be to little.
Help is very much appreciated!
T32Q!Wk~%24(KGrHqJ,!hgEzenct5CYBM6ujwgRm!~~0_12.JPG)
