Alternate configuration for 16E?
Hi everyone; Please excuse my [glow=red,2,300]extreme[/glow] newness.  ;)
Is it possible to have more than the 16 rotary encoders+ledrings on the 16e?
I want mine to have 48., with ledrings around each…
Is this possible?
Thanks!
Yup. I just found my own answer.
This is GREAT!
<snip>
*handling of up to 64 detented/non-detented rotary encoders
*handling of up to 128 buttons, touchsensors or similar digital input devices
*handling of up to 128 LEDs, relays, Digital-Analog-Converters or similar output devices. In multiplex mode a nearly unlimited number of LEDs, LED rings and LED digits can be driven
</snip>
So now, the question is: has anyone done a 64 encoder midibox before? Any thoughts or comments?
D
Don’t forget that that might cost you quite a bit…
You’ll have to use MIOS also, so you’ll need to modify some ASM code…
The enc_example3 supports 64 rotary encoders and 64 LED rings by default :slight_smile:
