Middle PIN=GND, left and right pins go to two different DIN pins?
I am using the STEC12E08 (with push button) and they work flawlessly (using DETENTED3 setting for MIOS). Methinks the STEC12E07 is just a 08 without push button and should work therefore…
MB64e uses MIOS_ENC_MODE_NON_DETENTED while MBFM uses MIOS_ENC_MODE_DETENTED2 by default. According to Peter MIOS_ENC_MODE_DETENTED3 is the more suitable one for STEC12E0x
Yod: do you already know how to change the setup_mbfm_v1.asm file and recompile the application? (see also README.txt)
on page 5 it says that “C” is the middle pin and on page 3 you can see that “C” is “ground” and is switching pins “A” and “B”, when the knob is turned.
So this is somehow strange - but if it works for you - never change a running system
