ALPS 10K linear sliders?
Hi All,
I was wondering, does anyone know if ALPS makes their linear slider pots (faders) in a 10K version? I was looking at the Farnel website and they only sell the linear ones in a 50K version.
Does anyone know if/where you can get the 10K linears, or will the 50K be ok to use?
Cheers.
Yes they do. If your in the US, Mouser sells them.
$7.00 - 100mm
$8.00 - 60mm
Also , I was told by someone (Rogic i think) that 50k would work. came up because i had found some joysticks i was going to order.(never ordered them though, due to minimum order of 30 dollars, and they had nothing else i needed)
Doesn’t the “B Taper” and “D Taper” mean they are logarithmic, not linear?
The Mouser catalog that I have lists the taper as linear. You can download the catalog page from any of the two links above.
