I have a lot of Taiwan Alpha 10k linear pots I’m using to mount on my panel (7mm holes).
The pots have a locking nut underneath, used to lock the orientation in place by resting in a hole underneath the panel (2.5 mm aluminum).
photo here:
http://avishowtech.com/mbhp/images/Pots2L.jpg
datasheet here:
http://avishowtech.com/mbhp/images/pot2data.jpg
Currently I do not have these holes designed in FP Express… should I have the holes in my design? If so, can you point me to someone else’s panel file so I can see how they spaced these holes
Or, could I do without these holes on the reverse side, using extra washers instead, screwing the pots on tight and preventing the pots from twisting out of place ?
As always, thanks for your replies.
Regards,
