Album by albpower2seq4sid
Here i will show to the community the stages of my buildings
Control Surface Finished
I used encoders I have found here and fit well
Base Board and CS connected
Both boards connected and working but without SID’s for now
Other point of vieew of the 2 boards
Base Board finished
Here the base board with all the components, including the 7 pin female DIN and right angle vertical DPDT switch
2 Board CS and Base connected other view
Really i’m very happy with this building so i shot my camera a lot of times
Preparing a wooden case
7 + 7 Channel Stereo Mixer
This is a mixer based on TL084 Quad OP-AMP, Hand made PCB. I needed this to mix SID, FM, 2 Analog Synths and other devices. The output of the mixer was connected to a PC line in input and record sounds track with audacity software
Core + LCD + AOUT_NG
This workbench is for testing purposes, for example, to test modules, configurations, etc.<br /><br />The Core PCB version in this picture was made by hand
SEQ V4 CS
Last night I got the SEQ V4 CS board soldered!!
CS for FM synth
Here i built a CS for the FM synth using a experimental board for the matrix and three 74HC595 and two 74HC165 and at the left two small PCB hand made with one 74HC165 each for the menu control
SEQ V4 CS
other sight of the SEQ V4 CS board. Last night i had a hard soldering session!! I soldered the encoders and leds, the last components to get soldered in this board.
FM Board with OPL3 Chip
I have already finished and soldered the FM board I conect altogether and the sound begins!!
