AINx4 problem
Hello again.
I have connect 20 Fader to a AINx4
Maby a little strange but it Used pin 13 to 32.
But if i slide the fader on pin 32 in Does not Respont.
i if slide the fader on pin 31 it react only it Send 2 notes.
And to make a Layout from Pin 32 to 13 it look like this.
R = Reponding only it sends 2notes
N = Not responding
N-R-R-N-R-N-N-R - N-R-R-N-R-N-N-R - N-R-R-N
As you see its the same Pattern
But what did i do Wrong?
Kind regards, Emile ballard
If you used MB64 setup
connection diagramm looks like :
http://www.ucapps.de…p/auaimbctg.pdf
and asm setup file part looks like:
; Setup File of TK's MIDIbox64
; Number of connected pots
; Allowed values: 1-64
#define DEFAULT_NUMBER_POTS	20 ; number of connected pots
; Multiplexers (AINX4 modules) connected? -> set this value to 1
; No multiplexer connected= -> set this value to 0, allowed number of pots in this case: 1-8
#define DEFAULT_MUX_ENABLED 1	; enable multiplexers
Regards,
Janis
Hi thanks for the reply i will look in to it.
But i just connect the other AINx4 module and that one just works fine.
i also connected the wires this time from 1 to 20.
so if i get my pots i will try the other AINx4 module again and see what will happin.
Thank anyway, and yes i made a MB64.
Kind regards, emile ballard
1 - Check the CORE with 8 unmuxed pots.If it is OK then … 2 - Check the board AIN4 , it seems is like a defect on it .
Thats for the extra thinking.
but as i sad before the Second AINx4 Module work like a Sharm.
but i look a little closer to the other AINx4 module and i Noticed one BIG soldering fault and a Little one.
so hopefully that will solve my problem.
but first i’m waiting on my Nice Digitast Buttons.
then the Pots will come :wink:
Thanks for everything, Spirit
