AINSER jitter report
Hi all
Just to tell that I achieve EXCELLENT jitter result at MCP3208 input with buffer and passive first order filter
I have to say I run “long cable” (30-40 cm but shielded)
Before testing the filter my jitter was around 5, allowing me to use 9 bit without jitter and 10 bit with low jitter, witch is enough for my need but I’m little perfectionist…
Now, the jitter monitor don’t return result for 70% of my fader scale (which is strange ? should be 0 ?), and only 1 for the top 30% area (certainly linked to the fact that we come closer to the positiv rail)
Anyway I check in MIOS debug mod with AINSER set to 11bit, absolutely 0 value coming in (if I don’t move the fader of course). 12bit still receive lot of random value, but in close range (jitter 1)
Best
JS
