Additional Buttons
In the old and current version of Midibox64 there are 64 poties but only 32Buttons with LED possible.
As a workaround you can use the pots input (analog) as button inputs. You only have to provide 0V or >0V (5V) on the analog input. The simples way is a pulldown resistor and a button that switches to 5V.
Even LEDs can be driven. Toggle mode is possible with a t-FlipFlop. Simly connect the Q -out to the analog (poti) input.
Easy and you dont need another Midi128 only for some buttons.
