Add Velocity in J5_Dout_V1.3
Hello
I would like to add velocity sensivity in this project: J5 Dout v1.3
i want to set Pin 7 at 1 when the velocity is bigger than 100 on one of other pin to controle the accent in my rythm box
and set the Pin 7 at 0 when this note is off
I think i must modifiy the prog in Main.inc but i don’t know what i must add
USER_MPROC_NotifyFoundEvent
;; forward to J5_DOUT_PinSet function
;; it expects: number of pin (0-7) in WREG
;; value in MIOS_PARAMETER1
;; store pin number
movwf TMP1
;; set the pin value depending on velocity:
;;    - 0x00: set pin to 0V
;;    - other values: set pin to 5V
movf MIOS_PARAMETER3, W
skpz
movlw 0x01
movwf TMP2
;; if the event was a note off event, zero value independent from velocity
movf MIOS_PARAMETER1, W
andlw 0xf0
xorlw 0x80
skpnz
clrf TMP2
Please can you help me
thank you
…maybe you have to ask your question in the “c programming” section… :wink:
Sorry mate… I have been meaning to reply to this ever since it hit RSS … I thinx it’s been sitting in a ficefox saved session over 5 reboots now hah…
Answer coming soon, if nobody beats me to it :wink:
Hi:
I can’t answer the question, but I was about to ask something similar.
I’m building some drum modules too, and I was planing to trigger them
with the modified MIDIbox CV as stated here:
http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_midibox_cv_with_a_dout
As this configuration provides 32 triggers, I want to add more than one
accent. At least 4, but could be one for every drum.
My programming skills are very limited, so any help will be great.
Thanks
