there are two small connectors - probably power and TTL midi signals. Unfortunatelly I dont have CME keyboard and I’m not able to check if i’m right.
IMHO there is no reason to make Waldorf Nano standalone (especially now, when there is much better Blofeld),
but there is also much more interesting module: Use Audio Plugiator - 7 synths based on creamware/sonicore plugins.
ASX pluging is cheapper then desktopop module and is really small - it could be possible to fit in 1U rack, or to build minimoog/propeth clone with mios based control surface :whistle:
EDIT:ASX manual - there is 2 pin midi in connection and 4 pin power connector onboard.
I have already a Plugiator which actually host an ASX board.
I had in mind a project to make a synth based on a Core32 board to control such an ASX board.
I have more time to think about such project but miss some hardware to build up my very first Core32 board (ordered from SmashTV).
The thing I still have to figure out is a way to layout the controller to make it efficient for the most intersting plug-ins available on the ASX: LightWave and Minimax are provided with the board, Pro12 and Prodyssey being available through an extra plug-in bundle (99 € roughly).
The trick is to organise the controller to merge the required control elements for these 4 plug-ins.
The common structure is 2 or 3 osc mixed down to 1 or 2 filters…
The most complex is the Lightwave which sounds like a good digital synth (a kind of simplifyed prophet VS).
The most analog like sounding are the 3 others Minimax (inspired from the Minimoog), the Pro12 (inspired from the Prophet 5) and the most intereting Prodyssey (inspired from the ARP Odyssey).
I was looking at the CME + ASX combo awhile back. But didnt like the feel of the CME keyboard. To many people were having problems with it aswell. So i left it. The plugiator module itself seems to be lacking controls. Bundling the ASX with a MB64 would totally solve that.
The hard part is to make a proper interface that would suit most plugins. I don’t think a core32 is a strict requirement and would probably make it harder as the MB64 hasnt been ported from MIOS8. Besides that the ASX module has it’s own USB port for MIDI connection.
I did not meant that the Core32 was required, it is just the first and only Midibox board I have so far …
And I also had in mind something combining a kind of MidiSeq altogether with some ASX control knobs and switches to provide something more user-friendly than the limited plugiator user interface: I had in mind to attempt to merge the more user-friendly old Creamware/SonicCore ASB module into something new, not only dedicated to MINIMAX but providing a solution for LightWave, Pro12 and Prodyssey (and maybe something for the Plugiator also).
Just a heads-up. By the look of things the Plugiator ASX board might be EOL. Thomann is no longer carrying the ASX version. And i had a search on the web and couldn’t find much stores who carry it either.
So i made the jump and ordered one from ebay for 149euro. I am not even close to starting this project, but would hate to miss out on it later because i couldn’t get the board anymore. First i need to give my MB-6582 it much needed attention and my MBFM project is also in a state of flux.
As far as the design goes, i had a look at the Arturia Origin. This is more or less what you describe in the sense of the interface. It combines a control interface and a sequencer.
Yep, I noticed the Arturia Origin, but for the moment it is far to expensive for me.
Moreover, I already own 2 Plugiator unit I bought on ebay with the full range of plugin so for me the ASX board are already here.
The ASX board (under CME brand) is also offered as a so called X-synth board provided by Icon (but I must admit I never saw some X-Synth board for sale, only their host masterkeybaord the “Inspire” series.
The availablity of the ASX board by Thomann is kind of changing month by month. Sometime you only have the plugiator available, sometime the ASX an extra plug-in bundle are also for sale.
By the way the price you paid for the ASX is fair as it was the price thomann had it for sale it the last 3 months
I have received the board. Have you ever found out what the power requirements of the ASX board is? It has a 4 pin power connector. So i would assume it requires 2 different voltages.
Is the board inside the Plugiator desktop module exactly the same?
I requested some more info from use-audio guys but I had no feedback so far except for a “we will give you answer asap message”.
If you are not to hurry, I will try to find time to make a few measurement to check what the pinout is and what the necesary wire are.
From what I see so far the plugiator is split in 3 boards:
1 power supply switch & connector + MIDI I/O connector: this one is really basic
1 ASX / X-Synth DSP board including USB and audio I/O: the most complex one
1 controller board which handles the plugiator user interface (AVR based microcontroller handling the 11 encoders, 10 swicthes, 8 leds and the 3 digit led display of the front panel): a kind of MIDIBOX board actually …
The link between the different boards is as follow:
power supply and midi connectors are linked with the main “ASX” board withe 3 connectors :
=> 1 is 4 wired
=> 2 are 2 wired
the front panel board is directly linked to the main “ASX” board with a unique strip connector
=> 1 is 4 wired
=> 2 are 2 wired
I assume the front panel connector is 8 pin one on the top left of the board. I would be gratefull if you could take some measurements. I have also e-mailed Use Audio but i don’t think it will get me anywhere.
Regarding for power requirement: the full Plugiator Module require a 9 VDC - 500 mA power supply.
That was just my impression. I couldn’t find the board anymore in Dutch Music Stores. And since Thomann wasnt carrying it either i came to that conclusion.
I have the full information PolyAT message inclusive but it is only on a draft paper so far …
My idea was to implement 4 differents things in this device:
a kind of MidiBox “dedicated” to these synths
a subset of the MIDIBox Seq v4
a midi translator tool allowing to remap midi message from one source to one destination (the idea behind this would be to allow ASB module to take control other ASX/plugiator board as they do not have exactly the same CC mapping !!!)
a MIDI preset interpolation feature to allow an alternate way of using the controller to adjust between two preset to build a third one
