Adapting MIOS to another LPC1769 board
Hello,
i have an board here with an LPC1769 on it, but it’s not the one from LPCxpresso. The pin assignment differs from the xpresso board.
How can i change the MIOS to fit this board? Is it sufficient to create a new mios32_board.c file with new definitions and fuctions or do i have to consider some other changes?
Best regards
Gregor
Why not just buy the right board.  They are cheep enough.
I guess the most obvious problem would be when special function pins used by MIOS32 are assigned to other functions on your board.
Potentially a lot of time and effort to resolve. Or maybe not, it depends on the board.
As was alluded to, the cost benefit balance probably isn’t there.
Most files under mios32/LPC17xx define IO pinnings which maybe have to be adapted depending on the board layout.
