Hi all,
after getting Code::Blocks to work properly with ACSim I ran into the next problem.
I’m using Port A to interface to some SRAM memory, so I need to disable the ADC and set up the port properly. This is the init function I use:
void SRAM_Init(void) __wparam
// disable the ADC which allocates the analog pins
// only needed if controls pins are connected to port A
ADCON1 = 0x07;
// put PortA in output mode
TRISAbits.TRISA0 = 0;
TRISAbits.TRISA1 = 0;
TRISAbits.TRISA2 = 0;
TRISAbits.TRISA3 = 0;
TRISAbits.TRISA5 = 0;
// set control lines
PORTAbits.RA5 = 1;
PORTAbits.RA3 = 1;
PORTAbits.RA2 = 1;
PORTAbits.RA0 = 0;
PORTAbits.RA1 = 0;
// configure RD4 as input for reading SRAM card status
TRISDbits.TRISD4 = 1;
return;
The code compiles fine for the RELEASE target. For the DEBUG target it gives me
error: 'ADCON1' undeclared (first use in this function)
and naturally the same for TRISAbits, PORTAbits, etc.
I suspect that this is related to something that ACSim would need to know about but does not yet? How would I add this information to make the code compile in DEBUG mode?
Best regards, ilmenator
these special parts aren’t yet defined in ACSim, I concentrated on the basic MIOS functions, but you can add them manually; there are already some PORTCbits and PORTDbits, so you’ll know where to paste it:
please add this to ACSim_mios.h:
// "pic18f452.h" typedefs
typedef union {
struct {
unsigned PCFG0:1;
unsigned PCFG1:1;
unsigned PCFG2:1;
unsigned PCFG3:1;
unsigned :1;
unsigned :1;
unsigned ADCS2:1;
unsigned ADFM:1;
} __ADCON1bits_t;
typedef union {
struct {
unsigned TRISA0:1;
unsigned TRISA1:1;
unsigned TRISA2:1;
unsigned TRISA3:1;
unsigned TRISA4:1;
unsigned TRISA5:1;
unsigned TRISA6:1;
unsigned :1;
} __TRISAbits_t;
typedef union {
struct {
unsigned RA0:1;
unsigned RA1:1;
unsigned RA2:1;
unsigned RA3:1;
unsigned RA4:1;
unsigned RA5:1;
unsigned RA6:1;
unsigned :1;
struct {
unsigned AN0:1;
unsigned AN1:1;
unsigned AN2:1;
unsigned AN3:1;
unsigned :1;
unsigned AN4:1;
unsigned OSC2:1;
unsigned :1;
struct {
unsigned :1;
unsigned :1;
unsigned VREFM:1;
unsigned VREFP:1;
unsigned T0CKI:1;
unsigned SS:1;
unsigned CLK0:1;
unsigned :1;
struct {
unsigned :1;
unsigned :1;
unsigned :1;
unsigned :1;
unsigned :1;
unsigned LVDIN:1;
unsigned :1;
unsigned :1;
} __PORTAbits_t;
and this to ACSim_mios.c:
// "pic18f452.h"
__ADCON1bits_t ADCON1bits;
__TRISAbits_t TRISAbits;
__PORTAbits_t PORTAbits;
basically, the typedefs are just copied from pic18f452.h and pasted to ACSim_mios.h. And a variable in ACSim_mios.c is instantiated.
I know this is probably a bit messy, but all this pic18fxxx.h/.c stuff needs a clean up anyway, so in order to get it running… :-\
Best,
Michael
