I just finished my AC sensorizer. I will be using it with some pressure sensors mounted on a glove under my finger tips ![]()
I’m not sure if the 2.5 m cable going from the MIDI box running AC Sensorizer to my glove with sensors should be shielded or not? The cable is carrying 5v, ground + 4 outputs from the sensors back to the Midibox. If you think shielded is best, then do I connect both ends? I have a feeling that you usually just ground one end of shielding, but I’m not sure what’s best in this case…
Thanks in advance
David
