Can anyone please tell me if there is a way to the following in Live 5 / 6:
While in the clips window I want to be able to assign a midi button to select the channel so I can view the waveform as it’s playing (i.e. so i can see when a breakdown is coming up)
The way to do it using a mouse is to click the clip’s box to the right hand side of the triangle that triggers the clip start.
I’ve tried mapping a midi button to the box, but when you use it ableton re-triggers the sample - which is a no no if you are in the middle of playing it live.
there is a way to toggle the view - that’s by using something like bome (spelling?) which maps midi commands to key strokes, so you can emulate the shift-tab. So that side is cool.
What I really need to know is does ableton 6 still re-trigger the clip when you select the “clip box” via midi?
but - very good call on using the arrow keys - I nearly forgot about those (slaps forehead)!
in Live 6 session view, you can click on the “pie” that’s displayed above the mixer for each track, the display will jump to the clip’s content straight on.
This works only if the clips are playing. You cannot focus on nonplaying clips waveform. I tried it at work over PC kayboard but I suposed it is same with MIDI. I don`t understand why do they they made it like this.
