I’m having trouble with DIN R5, just insert the ribbon on J1 and I receive on midi in an avalanche of messages (Buttons-note on / off).
I’m working on NG Default but I have tried also with Midio128, same problem. I tested resistance and welding on DIN and it all looks ok.
Have any of you ever encountered this problem?
I think it is also a short, on mios in default NG I receive continuous signals of buttons and related notes.
I tried to do a test with a simple Hello.NGC but same problem, mios appears on a continuous data stream “chn # 1 note on/off C1” of course the code is : EVENT_BUTTON id = 1 = LED fwd_id: NoteOn key = 1 type = range = 36 0:127 lcd_pos = 1:1:1 label =" Button #% 3i:% 3d "
Another thing that seems strange to me is that the red LED is continuously lit on the LPC1769 … this is right?
the red led on the LPC17 core is lit, when some kind of data is processed (like the hdd led on a computer). If there´s a short on the DIN module this would be normal since it processes data continously (impulse from din -> midi data out).
I´m a little confused about that button event you posted because it wouldn´t really make sense if it looks that way. Did you post it here exactly like in the *.ngc file?
To test a bit further, I´d suggest you create a new *ngc file and insert some simple button events with an id from 1 to 32 and the midi event NoteOn and key from 1 to 32 (to test all input pins on the DIN):
EVENT_BUTTON id=1 type=NoteOn key=1
EVENT_BUTTON id=2 type=NoteOn key=2
EVENT_BUTTON id=3 type=NoteOn key=3
EVENT_BUTTON id=4 type=NoteOn key=4
EVENT_BUTTON id=32 type=NoteOn key=32
After that you load it and look at the midi in monitor inside Mio Studio. If there is a continous stream of midi events still coming in, just let it stream for a few seconds and then cut the power of the LPC17 core (to stop the stream ).
Then you can study the stream and see, what kinds of notes appear in it. This could help narrowing down where the short sits.
The red led is continously lit even without DIN… and I begin to believe that the short is on the core
I tried with your code but same problem, practically is like an open flow of data streaming, any event that I assign to a DIN (and I tried with 2 different DIN) back as a loop on the midi monitor, below a link for a screen shot of the Mios so you can see the data message.
Ok, after your additional descriptions it really seems that there is a problem on the LPC17 core. The problem on my side would be to narrow down where this problem is, a remote diagnosis from here can be very hard.
You can try/check a few things:
What kind of computer are you using? PC or MAC?
if you are on a PC, I suggest you install the gm5 driver, it´s much more stable than the native windows driver.
Visually inspect all the soldering points on the board.
If you have access to a multimeter, check the complete core for the expected voltages (look at the LPC17 schematics).
Check all the parts, especially those which has a polarity and all the ICs if there are put in the right way.
I tested everything following the schematics and everything seems to work fine, all voltages are correct, at least the ones described (+3.3 V +5 V-)
and each IC is in the correct direction.
Also tested resistance, ok.
About the computer I use Mac but I don’t believe the problem is on the driver.
The thing I need to understand is why even without plug the DIN the led2 of the LPC remains continuously red, I think this is a clear sign that the problem lies in the core of the LPC but where?
I did a test, I only tried with the slot J3, I started to put in ground from D0 and so on and at the moment that I put on ground D6 data cycle stops “NO EVENTS”
Regarding the DIN “R5” I loaded 8 network 10k (obviously with the poles in the right place) and 4 capacitors 100nf, I hope this board do not need more resistor…
for the MBNG application this is normal, the LED is toggled with a very high frequency so that it looks like it’s permanently lit.
So, the issue is probably not related to the core module.
Are you sure, that the ribbon cable is connected correctly?
E.g. as far as I remember, a continuous stream will be generated if the cable is cable is plugged in the reversed direction into the socket.
These pictures might help to doublecheck this (they are for a different module, but with the same socket polarity):
The cable is positioned correctly, I tested with the same ribbon 2 DOUT and an AINSER64 and everything works correctly, instead on 2 DIN the same problem, I re-tested the resistors and also tried chance IC’s but no improvement, what tests can I still do?
what happens if only the first 74HC165 is plugged into the socket?
Expectation: MIDI events for the first 8 pins should be sent whenever D0..D7 inputs at J3 are grounded. No continuous toggles should be generated.
what happens if the DIN module is connected, and J8/9:SI is directly connected to Vs (ground) with a short wire?
Expectation: once you connect the cable, many Note On events should be sent, but only once. Thereafter no additional events should be generated anymore.
Once you disconnect the cable, many Note Off events should be sent, but again only once. No repeating note on/off…
but you get a MIDI event whenever a ground connection is done (and removed)? Just like if you would push a button?
I get a midi event only on pin D7
You notice this, when DIN module is connected, right?
What happens if the DIN module is not connected, and you repeat this test?
Yes without DIN is correct, On when I connect and Off when I disconnect.
And please also do the test with the single 74HC165, because it seems that with a single chip no continuous note off/on will be generated, right? Or does this mean, that they won’t be generated if all digital inputs (D0..D7) are connected to ground?
Right, with the single chip no continue on/off if DO..D7 is connect to ground.
