Anyone ever tried hooking up a capacitor between the middle pin and ground of the potentiometer while its connected to your midibox ?
I connected a 2200uF cap to one of the pots, and when I turn quickly the pot to some direction, and suddenly stop it, the value is decreased or increased logarythmically cause of the cap discharge time thru the pot itself to the ground
This can be useful to create really nice “analogish” fadeouts or fade ins
if you would like to use a physically smaller cap to privide ths same "smoothing " effect, do this:
With the positive side of the cap still connected to Ain,
wire a resistor between the wiper of the pot and Ain.
This will lengthen the time constant.
Time constant can easily be calculated as R*C (in ohms and farads). Basically if you scale the resitor up by a factor of 1000 then you can scale the cap *down* by a factor of 1000 and have the same response!
