a litle questions
heya!i am finishing my midibox64,i have already a lot of work…and i have 2 questions:
  1.  i have program it with mios,and after that,with Midibox 64 v2.i  power on,ready! Mios V1.03 etc etc…and…what shoould appear?? i have in the screen(with all pots pins to ground..or i think so)a reverb value.
2)Leds.if i dont change nothing…led 1 belong to button 1,led 2 to button 2..etc etc???i can change this? where?
thanks!!! :wink:
  1. You can arrange later witch dout register corresponds to each din register. this means that you can assign each group of 8 leds to a group af 8 buttons.
  2. Not sure what you should see exactly. connect the menu buttons and you’ll be pretty sure everything is ok!
heya!
ok,i ´ll explain it.
when i power on my core,programed with midibox64V2.1,in the lcd appears Ready!, after this, MidiBox 64 Thorsten Klose 2003 ©.ok, and after this, appears an int value of reverb. is it ok??? i think it could be that a pot line is not grounded,but i want know what screen i ´ll have to se if every thing is ok.
All unused pot lines *must* be pulled to ground. Otherwise the PIC will be stuffed up working out that random data.
Greets
