I found a cheap GLCd based on T6963C chip. It has 160 (W) × 128 (H) dots. It also has LED backlight. Is it a bit suitable with MIOS? I read that it’s slow but is it worth buying?
Datasheet here:
Datasheet here:
Hi Domas,
sure, it will work. You could connect it to the upcoming companion chip for best performance (search for the posting somewhere under Construction->Concepts), otherwise only uncritical applications like MB64 or MB64E can be used with it.
Note that a MIDIbox LC requires a 240x64 display so that all characters can be displayed. There are also some really cheap T6963C GLCDs with this resolution available.
Hi Thorsten,
I plan to have 25 encoder, 10 pots and ~40 buttons. Will it work normally with that 160 (W) × 128 (H) display. As I found it for 11$ ;D
Thanks,
Domas
