a big step forward
hi everyone
Long time ago (i think almost 2 years)i started with my sequencer-project first in mind and later in reality. Since so many things happend in my life i wasn´t able doing anything. SO: Today i reached a critical point, let´s say i finished my baby at the 50% level. I soldered all modules during a three-day-session.
Well, the next step will be:
1.) getting the buttons and the knobs with the main-knob (LCD´s and encoders are allready there)
2.) LED (blue ones, damm i like that)
3.) a PSU
4.) SD-CARD
5.) wiring all things and testing
6.) Front-Panel
7.) Enclosure (i am not sure if should make a rack-mount unit or an external box (wood))
8.) and so on :wink:
there is still a lot of work to do
as you can see on the picture, a beginners failure is obviously, all the IIC_Modules have the Midi-Ports soldered - which was a very mindless action … i could desolder them and put them on a seperate board … but what the heck
cheers
Good work! So you have a Core32, 2 DINx4, 2 DOUTx4, and the IICs?
1x DOUT, 3x DIN
the picture is blured since i used photo-app from my mobile
by the way, from my point of view the frontpanel seems to be going a real difficult operation. Although a frontpanel-design is already on ucapps i fear that i have to make some adjustments and to measure it exactly produces goosebumps.
another thing are the LED´s … there are many types available - blue preferred as mentioned, they have different “angles of light-emitting” and also different currents and maybe some sort of LED-clamps for fixation, the main-knob and the other sixteen knobs are very expensive compared to some parts, also spacers are needed
i have some other projects with many parts running, so it would be wisely ordering them together
