Forgive me if this problem is covered elsewhere. I’m getting so stuck notes with my 6581 Sammich, where there is indefinite and audible tones pitched to the last midi note played. It seems better / worse on certain patches. Any ideas what to check?
Another possibility is “wimpy” midi output on your keyboard. For some reason, my M-Audio 49e keyboard does the same thing. try changing the 1200 ohm pullup resistor on the 6N138 output to something like 390 ohms. You can try tack soldering in a parallel resistor on top of the 1200 ohm unit to see if that helps before removing and replacing a resistor. On second thought, if it happens to solve the problem, just leave the parallel resistor.
Yep, the notes stick on both speakers, both via with external MIDI and via Play button (F1). Looks like I’m on the hunt for a pair of 6582 or 8580? Do most 6581s have this issue with gates not closing all the way? Thanks!
