i have about 130 of these
it’s 2x50k A (stereo) sliders, good and very precise movement, is good for both pcb or wire soldering.
i sell this 2€ each.
Hi Stefano. Do you have a part number and maybe a manufacturer for the fader?
Thanks!
-drin
on the case is written:
50KA x 2
6236
near the frist line there is two symbol, a triangle with the marked edges and a circle with an “A” inside.
that’s all.
Another thing you should watch here is the label 50KA. If the pots are relatively new the A could mean audio taper. If the pots are old the A could mean linear. The best thing to do is place the slider in the middle of its travel and measure the resistance between the tap and each end with a meter. The value will be relatively equal if the pot is linear taper but will be noticably different if its audio taper.
Hope this is useful…
Regards,
Synapsys
