4xMBHP_CORE : need to solder LCD and MIDI components?
Hello,
I have a question : in a multiple MBHP_CORE set-up (for a MIDIbox SID), do I need to solder the LCD and MIDI part for cores #2, #3 and #4, since there will be no LCD for them, and MIDI should go through J11?
So, I could avoid to solder:
  • The regulator part: IC3, X1, C5 and C6 (power through J2)
  • The LCD part: P1, P2, T1, R4 (and R3?), but well use 1N4148 diodes for the CAN bus
  • The MIDI part: R5, R6, R7, R8, R11, D1 (recycled for CAN bus), IC2, J12, J13?
  • The DIN/DOUT buses: J8 and J9
  • The AIN/AOUT buses: J6 and J7
So, there remain only the PIC, the oscillator, pull-ups resistors and filtering caps, J2, J4,  J10, J11, and some pins of J15
Is it correct?
EDIT: and do I need 1 banckstick per core, or is it shared from core #1 to other cores?
Something like that:
Hi Alchemist,
Is it correct?
AFAIK you can leave out these parts except R9 and R10.
You can connect up to 8 Banksticks to one core.
They are shared between all cores.
Best regards
Marxon
Perfect! This is was I expected. Have a nice week-end!
I have an other related question : I see that I don’t have to interconnect MIDI Out connections. How do the MIOS / application upload work? Will the main core transmit ACK messages to MIOS Studio?
For the MB-6582 I put one after another in the first socket that had full MIDI IO connection with MIOS Studio and made sure I changed the PIC ID before uploading. Afterwards, I put the PICs back in their respective socket.
Thanks for the tip : I will program my 3 other PICs from the Core #0, this is a safe solution.
OK, I programmed the 3 other PICs then moved them on their MBHP_CORE
