**edited
This is the latest version for the Kobiconn DIN8 connector available at mouser and reichelt. Previous versions removed.
Pinswap fixed
**edited
Pinswap fixed
it is a very good idea.
Why did’nt you put some midi input?
Additional midi inputs are not supported on Seq4 atm. This is out only
Nice idea, I’m interested on a board for my MBSEQ ![]()
Proposals:
See also my backpanel as reference: http://www.ucapps.de/midibox_seq/mbseqv4_backpanel.png
Thanks TK, just the input I was looking for.
5th socket for the BLM connector: is there a diagram for the wiring?
Also, if I read your comment correctly, I can clamp the 5V rail directly to pins 12/13 with no 10K for a no jumper board? (I was wonder about this before laying this out)..
When you say 20mm between mounting holes and “socket side” at least, you are referring to the clearance for the profile in the case correct?
Not yet, but currently it isn’t relevant.
It’s only important that the socket can be mounted and soldered.
You could add a 7-pin SIL header, the connections can be defined later (there is no equivalent socket on the core module anyhow, cables have to be soldered directly at different places)
This socket could be used for other purposes as well by people who don’t own a BLM.
yes, thats allow.
yes
Most excellent!
Where do I sign up ![]()
Please move the BLM connector to the left side of the PCB! ![]()
(-> right side of the backpanel)
hehe. left is in the eye of the beholder
How’s this?
I’d move the left mount holes to the right of DIN7 (between this connector and the others) and move every part but din5 connectors a little bit to the left, including right mount holes.
Both changes just to shave off some pcb width ![]()
And, fix the couple of weird angle traces before nILS notices!
You’ll prolly run into some problems with the current isolate/track width settings on DIY etching. I’d rather add a few jumper wires than run tracks between pins. Also, most DIY etchers find it hard to etch and drill those small pads - unless you have a really nice way of making PCBs (share it!) you probably want to increase the size ond everything that’s copper.
Oh and fix those weird angles!
If you don’t mind sharing the .brd, some people (like me) might find it easier to look over it ![]()
SS: Good point about the board size
nILS: Define “weird angles”. I can get rid of the traces between the pins without any major changes but the isolate is a big as I can make it before I start getting into problems with the ground plane, what should I have it at ideally?. I also use the “drill assistant” ULP so the final product will have that layer added.
Thanks for the input.
The distance between DIN7 and MIDI connectors is not correct, it seems that you added the size of the clip at the left side by accident:
And I always thought I was the only one using windows to measure things!
Nice! My 2 cents:
Would the extra resistors for the LEDs fit on the PCB? Maybe somebody wants to use them, so they may be a good addition. At least adding only a soldering pad next to pins 6 and 10 of each PIC, without resistors, so one can add the resistors and LEDs if needed. Just a thought…
Then, looking at your PCB vs the schematics, I see you have connected pin 6 of the PICs to J2 (SV6 on your PCB). As far as I see, Pin 6 should be the “Power ON” LED, and pin 7 is the one that should go to J2. Am I wrong?
Nice! My 2 cents:
Damn, good eye. Your right, totally missed that. It should be connected to pin 7, not pin 6. Adding LEDs should not be a problem, i’ll look at it tonight..
Unfortunately DIN7 sockets are not available at Reichelt anymore, therefore I’ve to change the spec: use a 8pin socket
Reichelt Order numbers: MABP 8SN for the print socket, MAS 80SN for the plug
And here another idea: since the BLM will require an additional optocoupler and some resistors (a common TTL->MIDI IN and OUT circuit), these components could be added to the PCB as well (if still possible)
