36 Pots + 53 buttons + 1 Encoder
I’m finishing off the last bit of electronics for my panel and I’ve decided to use 1 encoder as a menu data wheel.
My encoder is from SMASHTV’s site and I’m confused on the wiring for the 3 pins.
Below is an image of the encoder:
Encoder wiring diagrams suggest 2 of the pins connect to a DIN module and 1 of them to VS.
Does it matter which one goes to VS?
sure this matters!
Encoder pins are normally named: A, B, C (common)
If I have Smash encoders right in mind the middle pin should be C (wired to Vss). A and B are the switches.
ALPS Encoder have a different connecting.
Someone can verify this please?
Gotcha
C is the middle one:
Thanks doc
