32-Channel Midibox LC
Hi Folks :slight_smile:
Spent some time of thinking about starting this topic or not. But as you can see, I finally decided to do it!
First the Backgound:
Some years ago (I think it must have been in 2006 or 2007) I started to build a midibox LC.
I finished all the boards I need and build custom PCBs for the LED’s, switches and everything else.
You can see some pictures of the stuff.
I don’t know why, but I stopped spending time fpr that project. Perhaps due to my job.
Now, after I’ve moved to a new place (2 years ago) I want to go back and start again with my music productions.
For that I’m going to finish my LC and expand it to 32 Channels. Another thing I don’t know any longer: I’ve enough Core, DIN, DOUT and MF PCBs to build this big thing. Amazing…
The last 2 weeks I connected my finished PCBs and did some tests. Everything is working. But I decided to change something.
So I have to build new PCBs for my buttons, for the pots and pot-indication and for the meters.
Due to that I designed a housing for all the stuff.
Not yet completely finished.
Just want to give you some impressions and keep you guys up to date.
Greetz :slight_smile:
Had some time:
I think it’s done.
Why not consider to take the Transport/Jog/Edit unit into the middle of the console?
Greets, Roger
I can so it later. But it’s a good idea.
I can swap the Transport/Jog/Edit unit 2 faderunits left.
I just have to do it before I build the case.
I think I’ll think about it :slight_smile:
EDIT: 4 Lines and each starts with “I” :slight_smile:
EDIT2: Picture added
+1 for middle, top being 3/4
Last night I finished the layout for the Meters :slight_smile:
Channel Buttons
why don’t you integrate the shift registers to your PCB ? this would avoid you a lot of wires inside your midibox
Good question…Another thing I have to think about :slight_smile:
julienvoirin inspired me to do a full PCB with all the shift registers and other stuff.
If I can do it the way I want to do, I just have to connect 1 ribbon cable to my core, 1 from this full PCB to the meters, 1 to the touch-sensors.
I hope it will work. Just a little wiring in eagle to do:
if you can manufacture such a huge PCB i will ask you to make me one (not for a LC but for my custom Matrix1000 controller) !
good luck with wiring, remember that you can switch wires between shift registers and pots/encoder/buttons and redefine them later in the files to compile :thumbsup:
Yes I know. Without that feature I think it would be impossible :slight_smile:
Still some connections missing, but nearly 90% done…
great job :thumbsup: are you expert ?
I don’t think so.
Because I’ve still 5-10 connections I can’t solve. So I’ve to mount some isolated wires :frowning:
i’ve looked at the circuit .. Are you sure about the resistor SIL for the LEDs ? usually it is :
SRoutput–Led–R–Ground
it seems different here (and easy to solve). i guess you mismatched with shift registers for inputs
it’s OK now i’ve better looked : adjacent pins are a resistor isn’t it ?
i advise you mini resistor (1/8W) : cheap but hard to find
pin 1+2 is one resistor, 3+4 the next one :slight_smile:
I just want to thank the inventor of caffeine :slight_smile:
7 wires left. I hope I can get them on the PCB…
Stay tuned for the next status update *smile*
Finished.
Still have some single wires I’ve to solder by hand.
The connectors are wrong in my 3D animation. Sorry for that. Didn’t find the correct ones.
