One circuit board works well after testing with 64 switches, the other board does not.
There is only one pin contact working for that module, the other pins do not seem to make any contact. I measured the voltage, all power pins on the 5-pin-connectors on the module show nearly 5V OK. But only that pin on the board triggers a core module message that is triggering DIN 128 on/off.
What can I do to check what has gone wrong on that particular module?
sorry for me taking so long to respond… but life beyond MIDI box needed my attention ;)
Thanks to Your hints I was able to find the errors and correct them. It was a short circuit exactly where You pointed to and there were some poor soldering contacts, too. Having done that the two DIN4-modules work fine and connect nicely to 60 switches in my old organ. Now it is time to look after the AIN4-modules.
