2x 2x 40 displays
Hallo
wird das zweite display für den neuen seqenzer einfach parallel zum ersten geschaltet?
gruss
andreas
Connectivity: Both displays have to be connected to the same data and control pins at J15, only the E (enable) input of the second LCD requires a dedicated output (pin C.4, J10:RC) which is not routed to J15 and therefore has to be soldered directly to the core module.
Wiring Diagram: http://www.ucapps.de/mbhp/mbhp_2xclcd.pdf
