It’s probably one of these, if not, I’ll help more later (well, you can start by checking solder joints at JMI/JMO, the socket for 6N138, the DIN sockets etc.)
Regarding voltage:
I’ll assume you haven’t installed the 6581 yet.
12.44V is not too high. Regulated power supplies aren’t perfect. That voltage might drop after installing SIDs, but even if not, it’s fine, you won’t fry the SIDs.
Since the LCD is working and it boots, I can assume 5V supply is good, so the 12.44V would have nothing to do with MIDI In not working.
TEST MIDI2: put the PIC out of the socket and loopback the MIDI IO ports at the Rx/Tx pins like demonstrated in mbhp_core_extract_io_loopback.gif. The core module has to be powered for this test! Repeat the loopback test of the previous chapter.
which is easily done by removing the PIC and inserting some thin wire (like a cut resistor lead bent into a U-shape) into the Tx and Rx pins.
Alternatively, leave the PIC installed, remove shunts from JMI and JMO and connect the MIDDLE pin of JMI to the MIDDLE pin of JMO. This disconnects the PIC from the MIDI In/Out circuits and loops-back the MIDI In signal to MIDI Out.
You need to get MIDI loopback working in order to prove the 6N138 is working, as well as your MIDI interface, MIOS Studio setup, drivers, etc. i.e. prove that the PIC is receiving MIDI but not actually working. If the 6N138 is not working then it is easily replaced (by me, if you can’t find one quicker yourself).
Cool I will have a look at this tonight, the diagram for this on the midi trouble shooting page was kinda hard for me to relate to the sammich.
I don’t have my unit in front of me, where are the Tx and Rx pins?
Any tips on removing the pic?
“Alternatively, leave the PIC installed, remove shunts from JMI and JMO and connect the MIDDLE pin of JMI to the MIDDLE pin of JMO. This disconnects the PIC from the MIDI In/Out circuits and loops-back the MIDI In signal to MIDI Out.”
this sound like the easier option (so I don’t damage the pic) would cut resistor wire held on to the pins work?
Designators (like R5/R6) are the same. Headers are slightly different, and it’s pretty clear which is the PIC and which is the 6N138.
That diagram linked to in the previous post shows the corner of the PIC and which pins they are.
or if it is particularly stubborn,
It should, but it would be tricky to maintain while driving MIOS Studio. If you have thin bendy wire, cut two lengths, wrap each around the pin first, then twist together. Or use alligator clips to clamp on the middle pin (without shorting with the adjacent pins).
I was not confidant removing the pic, I went to jay car and asked for an ic pick yesterday when I ordered bought another 6n138 (just in case that was faulty) and the guy recons he never seen one??? I bridged middle pins of the jmo & jmi.
I did not see any mid fed back loop message?
Is this what I should have expected?
the CS was not connected if that make any difference?
I will perform led test, do the shunts need to be installed on jmo & jmi headers?
If you connect middle pins of JMI and JMO then yes, you should expect MIDI loopback… events going into the sammichSID via MIDI In should be echoed back out the MIDI Out.
Test your MIDI works by actually looping back the cable, i.e. connect MIDI In to MIDI Out, run some tests.
Run same tests using the sammichSID. If you don’t get MIDI echoed back then the problem is perhaps the 6N138.
Do you get the same results when just using a MIDI cable to connect PC’s MIDI In to MIDI Out?
What is strange here is you say you got messages from the PIC, i.e. the “upload request” messages, so the sammichSID’s MIDI Out is working.
Try the short between JMI and JMO middle pins, but with sammichSID MIDI In disconnected. i.e. test if you are getting garbage data from the MIDI In circuit when there is no MIDI going into the sammichSID. It’s possible you have a bad solder joint (or short) somewhere in the MIDI In circuit, i.e. around the 6N138, the resistors, etc. perhaps the 6N138 has bad ground joint or bad +5V joint… perform the voltage check tests from the build guide again to check it is all good.
I just found a strange issue. When I insert a Midi Cable into {MIDI IN} the large ground pad for the DIN connector is shorted to the right round pad of J13 and this happens only when I use my MOTU Ultralight interface. Also the middle pad on J13 does not seem to connect with the large ground pad.
When I use my M-Audio MIDIsport uno it no longer shorts ground to the right side round pad of J13 and the middle ground pad on J13
still does not connect to the large ground pad. I hope this makes at least a little sense.
6581 SIDs get hot… not much you can do about that, apart from stick on some heatsinks if you want (see other threads for ideas). With a regulated 12V DC input (required for 6581!) then the heatsinks and ventilation should be enough. Perhaps warming up caused a nearly bad solder joint to go fully bad, or something.
One other thing to check… if you’re using a “high-power LCD backlight”, be sure use JBL set to 12V, shunt in JR4, and turn the brightness pot to half-way or less. You would not want JBL set to 5V, as this will only add more heat to the 5V regulator, which is under enough strain as it is, supplying those power-hungry 6581 SIDs.
Were the buttons and knobs working at some point, and then stopped working entirely?
Did you already install the banksticks and uploaded the default patches? Just thinking perhaps it is set to a sequence patch and note events are triggering the sequence. From memory, the last default patch is Neo Zelda or likesuchas, and immediately after uploading the 128 patches, the “current” patch is the last patch. Or it could be set to some other patch. What is it showing on the LCD?
