18LF452 strangeness
Hi there
I have a strange(I think)  problem.
I have two 18F452’s programmed with the bootloader, and MIOS 1.9e . both of these work great.
I also have and 18LF452 programmed with the bootloader. If I program this chip with the MIDI loopback test, it works fine.
The bootloader programs fine, however when I try to upload MIOS via mios studio, I get the following errors :
Starting upload of mios_v1_9e_pic18f452.hex
Hex file contains code in MIOS range, forcing reboot!
Received Upload Request
Sending block 00000400-000004FF
Received Checksum: 0F - Error
Sending block 00000500-000005FF
Error: Received unexpected Upload Request
Aborting after 16 errors
Any ideas ? Or should I be using a different bootloader for the 18LF series ?
Thanx
Thys
Re: MIOS Upload fails…
The LF should behave the same way as the F… Weird…
Yes, it should behave like a common PIC18F452
Maybe an issue with your programmer? Which one did you use? And did you perform a verify after programming the bootloader to check the flash content?
Maybe the code memory protection is activated, so that flash cannot be overwritten via software?
I used a classic TAIT serial programmerand ICProg 1.05E , the same one I used to program the two working 18F452’s
I Also read back the contents and compared to the hex file, and all is OK
I have also verified that the code protection is the same as the others , Config 5 == C00F
Thanx
Thys
Hm, then I don’t have any ideal for the reason…
ICProg has a readout function, right? What has been written between 0x400 and 0x5ff?
