I think until the MB64 18f port is done, you just have to change the text files manually and reassemble the main.asm. I know what you mean about not having a clue. I have just started trying to learn how TK wrote this stuff, and it takes quite a bit of work. Have you loaded the ain64_din128_dout128_v1_3 firmware. This is where I would start if I were you.
I think I made a mistake. The ain64 test example only shows you how to drive the pots, leds and buttons. It doesn’t have any midi implementation. I think your code is correct though. It doesn’t matter if you have a dout or not. I think that the only example programs that send midi are the encoder examples and the midi tc box. You might have to look at the encoder examples and try to put similar routines in the ain64 test example. Sorry if I confused you.
Yeah i burnt the edited ain64_din128_dout128_v1_3 firmware, which worked, but i get no menu - just “waiting for AIN or DIN”.
I wanted the menu so i could enable midi learn mode and midi merger mode.
I’ve looked thru the other firmwares, and read some of the functions, but i just dont understand at all.
i might just have to use the ain64_din128_dout128_v1_3 firmware, and play my midi parts/record my pot tweaks seperately, and find some app to route the incoming midi signal to the cc# i need  :'(
EDIT: I just noticed that my exact specification is the same as midibox plus 16 - is there a mios port of that firmware?
