Couldn’t find something like it so I ask thee here. Could I use ±15Volt PSU instead of ±12V for AOUT_LC (for midibox CV, SID and seq)
Thank you all!
Aris
Thank you all!
Aris
I’d advise against giving something ±15Volts when ±12Volts is required..
But, it’ll be a piece of piss to convert a ±15 to ±12.. assuming it has normal boring regulators in it..
Look for the 7815 and the 7915 regulators and swap them with 7812 & 7912’s respectively.
Regards
Mike
edit.. and if you can’t get inside your power supply or it’s not practical, you could use the +12volt & -12volt regulators to drop the ±15 to ±12Volts..
See here:
http://www.midibox.org/forum/index.php/topic,12531.0.html
Summary: the TL072 (the only chip in the design which gets +/- supply) will happily run on +/-15V.
Thanks guys for the answers,
I will put it under 15 v and tell you what happens (probably nothing)
The thing is that my modular setup has a ±15 v PSU I’ve made and I wouldn’t like to downgrade it since it will feed some yusynth modules as well
So I’ll check it and get back to you
Ummm.. it seems I’ve done something wrong and I’ve done it twice.. When I set it to 12/4 bits, the 4bits seems to work (almost) but all the others are just dead.. I have to follow the signal trail up to TL072 to see if the problem is on the opamp or at the 74hc595..
When I go to calibrate, it is just the same voltage throughout the range. ![]()
just to be sure, you know that you first need to recompile/upload your application with AOUT mode set for aout_lc? just today there was another midiboxer on the chat who tried to get the LC running and didn’t know this. E.g. the Seq app is set for a regular (MAX525) AOUT by default, which gives strange results when using this setting with a LC.
S
AAAAAAAAAAAAAAAARRRRRRRRRGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHHH!
I’m a pure cretin!!
Haha ![]()
glad I could help ![]()
Works like a charm now!!
So to answer my own question ±15volts will do fine on aout_lc!
Thank you all guys!
(and sorry for my stupidity :-[
