I want to use the midibox to interface quadrature encoders (inkremental drehgeber). It works fine with 7 bit but i would like to have a resolution of 14 bit. Is there a simple way to implement this with the midibox. Maybe with the pitchbend?
Thanks
zoe
I’m sure you could encode it into pitchbend data ( I think LC does this) but your application or midi hardware wouldn’t know how to interpret it unless it is compatible with such data… anyway, I don’t really know, I’m just guessing :-[
yes, the hardware has to support 14-bit values. Most prefered are NRPNs or SysEx streams.
The realisation is simple, the enc_speed example is the smallest program which supports up to 16 bit, and it depends on the hardware in which way this number has to be transmitted.
I am planning some kind of robotdevice, and need to read 14 (or16) bit, from standard encoders, and send them to the computer. (5 encoders total)
I did try this with the enc_speed example and it works nice. (but only sending to the LCD):
what do i have to change in the code to get these values into the computer? And what is the best kind of stream (pitchbend, NRPNs or SysEx)?
And just that i have some kind of idea how fast i can move the encoder, how many ticks per second can the pic handle? Thats because i must know the position of my little encoders (robotaxis) very precisly.
