128 - transmission distance
Hi there, I am making a 128 - nearly there - and was wondering if anybody could tell me how long the cable can be between a DIN Module and a switch ?
Thanks
Pete
Really no idea. But as the DIN works with a 10k pullup resistor (from 0V to 5V) it should be pretty long. I would guess like 5m and more (and even much more if u use those “geschirmte” cables (german… those cables, where the ground cable surrounds the main one… whatever).
*IF* you have problems you can lower the pullup to 4,7k or even 1k (also I would stick to 10k). But I dont think so.
Just try it out and post it!  ;D
I use a prototyp control glove with 5 m of “shielded” cable connected to a Midibox16 without majors problems …
But i notice the neons (fluo tubes) introduce some jittering in the signal … when the glove is close the fluo lamp … like a speed LFO …   :slight_smile:  … but not really usefull !!!   ;D
Thanks for the one word, gilles: shielded! Thats what I meant…  ;D
I don’t really know if it’s the right word … but it’s seems to be “understandable” …  ;D ;D ;D
Thanks for the info - I’m running about ten meters so even sheilding might not sort it out, so I think I’m going to have a bank of relays for the switches, the bigger problem is my 128 doesn’t work, but I will be posting a question about that later once I’ve checked the forum for any clues as to what I have done wrong - right now just working on contingencies for the project.
Pete
