Hi - I’m relatively new to this MIDI stuff but I had a few questions about 10/14/whatever-bit precision midi controls
I’m wanting to build a midi controller for a VJ’ing application and I desire extra precision controllers because if I want to control an object’s position on screen via midi - 800/127 = 6 pixels per midi unit, which isn’t precise enough. with 14-bit midi i’d be able to go up to a resolution of 16384 before having a problem. (yes. a possible solution is to use rotary encoders.)
For DJ’ing apps, putting your pitch slider on a 7-bit midi slider is… non optimal. Again a 14-bit slider would be useful. Admittedly Traktor (my DJ program of choice) doesn’t yet support this and i’m guessing the response will be “use a rotary encoder”.
I realize that using rotary encoders solves a lot of these problems but they are no where near as “nice” to use as sliders/knobs etc. I’m also aware there are jitter / etc problems when you try to use higher precision controllers but I was wanting to get some feedback/pick people’s brains on their thoughts about 10/14/21/28 bit precision controllers (the last two being VERY non standard, but doable if you are writing the software on the other end. Though anything beyond 14 bit is overkill, and getting pots/sliders with that kind of precision would be quite difficult)
