1 button to rotate between bank sticks?
The title says it all ;D, has anyone done this?
Ideally:1 press of the button gets next bank stick selected, when the current bank is the last one , selection goes back to the beginning.
thanks!
edited:and then I found a possible answer: http://www.midibox.org/forum/index.php?topic=3925.0
so, CS_MENU_MS_NotifyBankChange has the wanted behavior already? need to know before committing to a certain panel layout :-[
Yes, this is possible.
hehe, thanks!, kind of waited a little more complex answer, ok let’s elaborate then:
so, to have this button can I define it? where?, or should I just take an existing button and have it call this NotifyBankChange, any lead can help ;D
Most of the answer is already given in the thread you posted :wink:
You want to add the additional buttons in cs_menu_io_tables.inc and program the functionality in cs_menu_buttons.inc.
been digging on both v1.7 and v2 files… some stuff is placed on different archives but now I know what to look for ;D.
I wonder if anything changed from that 2005 thread :smiley:
no, MBSID V2 is just a fake to sell more MBHP modules - nothing but the version number has changed. :wink:
P.S.: IO functions are now defined in setup_*.asm
…MBSID V2 is just a fake to sell more MBHP modules…
I knew it! ;D
thanks TK!
let’s suppose i’ll use the SID3 button:
CS_MENU_BUTTON_SID3
movlw 0x00
movwf SID_BANK
goto CS_MENU_MS_NotifyBankChange
this line “movlw 0x00” selects bankstick A0, right? and “movlw 0x01” would select bankstick A1?
so, if this is correct, it would not work as I wish, just one button to select next available bankstick on each press and back to first if we already have selected the last one ???
sorry if this is somehow obvious, but I have not the slightest idea about how to hack my way to this mod, just a big desire to have it ;D
You need to store the actually selected bankstick number somewhere.
If the up button is pressed check if the number equals [numberOfBanksticks]. If so set it to 0 else add 1 to it. Call NotifyBankChange.
If the down button is pressed check if the selected one is 0. If so set it to [numberOfBanksticks-1] else subtract 1 from it. Call NotifyBankChange.
Done.
:smiley:
almost there with the logic fossi, but I want 1 button, not 2 ;D, I guess is time to go to the programming section on the forum.
btw. why 1 button only you may ask, easy: to save panel space
Um, well that doesn’t change anything about what I’ve written…
I agree
means: When you are in the last bank the “next bank” will be the same (=same number), because its the last bank already. If this happens … goto bank 0. It’s like a circle
Hope that helped.
greetz
