I only see one mention of them in the Deutsch forum. Around how much are the average i/o pins looking for with stuff like this (pullups on the DINs and LED current limiters)?
Just being safe. ![]()
George
George
1/8 watt is fine if they are pullup resistors.
Anyone disagree? letās see⦠.125 is 1/8 watt soā¦
I=V/R
5V / 10000 = .0005
^volts ^resistance ^current
Each resistor lets through .5mA (amirite?)
P=IV
.005 * 5 = .025
^I ^V ^P (watts)
Each resistor dissapates .025 watts, 5 times less than the max of a 1/8th watt
Yep. I hope.
Thanks!
So Iām fine on 10k pullups then.
What does the average 3 or 5mm āstandard powerā LED pull?
(sounding lazy as s*** right now)
George
Iāll look around a bit anyway. ![]()
Hey again,
Around the middle of this page:
http://www.opamp-electronics.com/tutorials/special_purpose_diodes_3_03_10.htm
thereās a 6V LED circuit with a 220ohm, and he calculates it to 88mW and says the 1/8W is enough, so I guess Iāll go with those.
Take Care,
George (building a giant Digikey order and a drill press and a MIDIBox simultaneously ā¦perhaps)
