1-16 & 17-32 Button + LED
I tried searching for info on this, to no avail.
Can someone please point me to where I can find out how to wire up a dedicated LED when i’m viewing steps 17-32, and how to wire up the dedicated button for this (From memory, F4 does this, do I just wire up another switch in parallel?)
The DIN / DOUT wiring PDF’s for the SEQ 3 mentions this button / LED, but does not seem to tell me where to wire it up etc.
Any help is much appreciated.
Regards
Mike
It’s documented in the setup_*.asm file
E.g., setup_mbseq_v3.asm, search for “Step”
Note that you are able to change the pin assignments as required.
