0 Ohm 16pin DIP shorting bridge
Anyone,
I am looking for a 0 ohm shorting bridge to use on a DOUT card in place of the ULN2803 driver chip.
Would appreciate help finding same if anyone knows a source.
Thanks,
Johnc
Some wire? Sorry if this is a noob answer :slight_smile:
Some wire?
Only a solution if its a permanent fixture. But 0 ohm resistors are basically wire so not such a daft answer…
You may have to search high and low for such a dip network, what about using 8 x DIP switches?
Easily obtainable and removable if required?
S
This is the kind of thing you need http://uk.farnell.com/harwin/d6216-01/header-dil-16way/dp/176362 just solder wires across the pins to make the bridges.
Should be available from Farnell’s US centre in Newark.
Hope this helps
Tim..
